vcScope
Scope is a collection of statements in a program.
Module: vcExecutor
Children: vcRoutine, vcElseIfScope
Referenced by: vcIfStatement.ElseScope, vcIfStatement.ThenScope, vcProcessIfStatement.ElseScope, vcProcessIfStatement.ThenScope, ... (see more)
vcProcessWhileStatement.Scope
vcScopeStatement.Scope
vcStatement.ParentScope
vcStatement.Scopes
vcStatementHelper.GetActiveScope()
ParentStatementvcStatementRGets the statement that owns the scope, for example a conditional If or While statement
that has a nested block of statements; otherwise the value is None for routines.
StatementsvcObservableList[vcStatement]RGets a list of statements belonging to the scope.
clearNoneNoneDeletes all statements in the scope.
createStatementvcStatementvcStatementType statementType,
Optional Keyword[index = Integer]
Creates a new statement of a given type in the scope.
statementType (vcStatementType): Type for the statement to be created.
Optional: index (Integer): Index for the new statement. The default index value is -1 which adds the new statement to the end of the scope.
ValueError: When creating a break or continue statement type outside of a loop.
ValueError: When statement is non-requirement statement and added to requirement statement scope.
ValueError: When statement is requirement statement and added to non-requirement statement scope.
ValueError: When creating a non-process statement in a process executor.
ValueError: When creating a process statement in a robot executor.
vcStatement: Created statement.
moveStatementNonevcStatement statement,
Integer newIndex
Moves statement to different index in list.
NameParametersDescription
OnScopeExecutedbool isImmediateTriggered when a scope is executed.
isImmediate (bool): Defines whether the scope was executed in immediate mode (non time-consuming mode) or not.
